will not switch into higher gears. The odometer acts like the rpm gauge when at a stop. I replaced output sensor problem persist.
Apr 22, 2017 at 12:56 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
HMAC300
AUTOMOTIVE REPAIR CONTRIBUTOR
scan for codes first, but sounds like transmission is in limp mode. so may be the transmission has failed. best to have a transmission professional scan this for codes for a better diagnosis.
