Transmission problems
136,500 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
LINDA MOODY
Transmission jumps from first to third on take off and stays in third until you park it then drains the battery.
Oct 31, 2016 at 5:22 AM
  • 55,732 POSTS
Hey LINDA
It sounds like the battery could be causing the problem. If the system is running on low voltage because the alternator cannot keep up it will mess with the transmission, Also check the transmission fluid level.
Here are a couple of guides to help you
https://www.2carpros.com/articles/car-battery-dead-overnight
and
and
Please let us know what you find so it will help others.
Best, Ken
Nov 2, 2016 at 10:30 AM
