Transmission problems
200,000 MILES • V6 • AUTOMATIC
RJSP72214
  • 5 POSTS
When leaving my house today, my van was doing great, shifting all the gears and everything. I got maybe four miles from my house and it was like the van kicked out of gear. I turned the van off for approximately ten minutes and started it back up, it did the same thing, switched gears perfectly then suddenly kicked out. Any ideas on what this could be.
Jan 1, 2018 at 10:09 AM
HARRY P
  • 2,292 POSTS
What do you mean by "kicked out?" Would it not move at all? Or was it only going up to like thirty mph? If it is the second thing, that is called "limp mode." Limp mode occurs when the transmission computer detects an issue and, in order to prevent further damage, disables certain functions and leaves it so you can "limp" to the mechanic. You should get it to a transmission shop and have them scan it. Aamco is usually offering a free diagnostic if you tell them that AutoZone sent you. At least they do that here.
Jan 1, 2018 at 11:03 AM
RJSP72214
  • 5 POSTS
By "kicked out" it will not do anything, it is like it is in park. it will not even go in reverse. But if you cut it off and restart it after a few minutes it pulls good again for about a mile or so.
Jan 1, 2018 at 10:03 PM
HARRY P
  • 2,292 POSTS
Well I would be guessing here, but I would bet that your fluid pressure is dropping too low and then the solenoids and clutches cannot do what they need to do. This could be happening if you have a very dirty filter, or if the screen in the transmission fluid pump is clogged. Do you know when the last time was that the transmission was serviced (fluid changed and new filter installed)?
Jan 2, 2018 at 12:14 PM
RJSP72214
  • 5 POSTS
I honestly have no clue, but I am going to check it out. I heard the same thing from some of my family and friends as well. Thank you, I appreciate your help.
Jan 2, 2018 at 1:49 PM
HARRY P
  • 2,292 POSTS
No problem! Please keep us posted, as the information might be useful to someone down the road. And of course let us know if there is anything else that we can do for you.
Jan 2, 2018 at 8:46 PM
RJSP72214
  • 5 POSTS
Figured it out, it was the filter, took the filter off it was completely stopped up...replaced it along with the gasket and so far ot seems to be running good
Jan 10, 2018 at 12:16 AM
HARRY P
  • 2,292 POSTS
Hey I'm glad to read that you got it figured out and it wasn't terribly expensive. I'm always glad to help. Please come back any time.
Jan 10, 2018 at 10:24 AM
RJSP72214
  • 5 POSTS
Yeah, after asking ten different mechanics and getting different responses I figured heck with it I would try that first and then go with everything else that was mentioned...which most mechanics I asked said either solenoids or sensors or that it needed rebuilt
Jan 10, 2018 at 2:53 PM
  • 55,816 POSTS
Glad you could get it fixed. Please use 2CarPros anytime we are here to help
Cheers, Ken
Jan 12, 2018 at 10:17 AM
