if no check engine light on have a transmission specialist check this. it may be a clutch seal or clutch pak going bad. If you can check transmission fluid if dark brown or black then it is time for a rebuild.
Jun 6, 2017 at 12:10 AM
LEQUELS
MEMBER
Thank you, fluid seams to be in good shape. I am considering a filter change and a look into the pan. no codes and sometimes shifts better than other times.
Jun 6, 2017 at 2:24 AM
HMAC300
✓Experienced Mechanic
it may help but if you see large pieces, not like little grindings as that is normal from thrust washer wear.
