Transmission problems
2003 CHEVROLET TAHOE
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
LEQUELS
shift hesitation between second and third.
Jun 5, 2017 at 11:38 PM
HMAC300
  • 48,601 POSTS
if no check engine light on have a transmission specialist check this. it may be a clutch seal or clutch pak going bad. If you can check transmission fluid if dark brown or black then it is time for a rebuild.
Jun 6, 2017 at 12:10 AM
LEQUELS
Thank you, fluid seams to be in good shape. I am considering a filter change and a look into the pan. no codes and sometimes shifts better than other times.
Jun 6, 2017 at 2:24 AM
HMAC300
  • 48,601 POSTS
it may help but if you see large pieces, not like little grindings as that is normal from thrust washer wear.
Jun 6, 2017 at 2:34 AM
