Transmission will not shift into third gear or overdrive
189,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
CURTIS ANDERSON
My truck won’t shift into 3rd or overdrive it just stays in 2nd won’t even try to shift into third. would it maybe be the solenoids?
Mar 7, 2021 at 7:43 AM
Good morning,
Yes, it could be the 2-3 shift solenoid. If it is bad, the overdrive will not function.
I attached a picture of the location with the pan off for you. You need to verify power to the solenoid with the key on first.
Mar 7, 2021 at 6:38 PM
