Transmission not shifting properly
22,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JHENSLEY556
My truck will only go in 1st and 2and gear a plug on the side of my transmission the wires are broke off.
Mar 10, 2022 at 7:55 AM
  • 110,251 POSTS
Did the connector break or the component it is attached to? Also, can you upload a picture of the connector, so I know specifically which harness you are dealing with?
I have a feeling it is the transmission range sensor, but I need to confirm. Take a look at the pic below and let me know if the wire colors in the pic match what you have.
See pic below.
Mar 10, 2022 at 12:09 PM
