Transmission problem no fifth gear
62,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
PATTY KEENEY
On my way to Texas from Missouri it would not go into gears 1, 3, and 5. It stopped as quickly as it started, but fifth gear would just rev the motor. There was no power to the wheels. Then there was the loudest grinding noise (sounded like rocks in the engine) in gears 1,2,3, neutral, and reverse. Fourth gear worked fine. When I returned home I was told the Synchronizer went out and caused the fluid to leak out and the gears were shot. I had the transmission replaced and before I put 50 miles on it the same exact thing happened. No fifth gear, sounds like rocks in the engine (even in neutral) and fourth gear works great. I was told I was sold a bad transmission and it needs to be replaced again. I could really use some advise!
Nov 24, 2019 at 1:45 PM
  • 55,709 POSTS
Do you have a teenager that drives the car? The reason I ask is the 5th gear is a smaller gear and can fail when abused. If not the transmission is bad again and needs replacement. here is a video of the job being done on a similar car. (the process is the same).
https://youtu.be/6N6b5F2ChyE
Nov 26, 2019 at 6:35 AM
