Transmission will not shift in gear and makes a whining noise
91,000 MILES • 3.5L • 6 CYL • AUTOMATIC
NANA1127
  • 5 POSTS
It started making a new noise like something flapping. had fluid changed last week it looked clean and didn't smell burnt and nothing was in it. help please I have a son on dialysis and on kidney list. I need my car running good so if he is selected to get a kidney I can get him to PA. from W.V. in time for transplant. Thank you in advance.
Dec 2, 2019 at 5:48 AM
  • 55,694 POSTS
It sounds like the fluid level could be low. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response. Here is how you check the fluid level, instruction in the diagrams below. It looks like they needed to ruin the car for five minutes to finish adding fluid?
Fluid Types
Transmission Fluid Type
Type .................... MERCON V XT-5-QM
Capacities
Transmission Fluid .................... 10.0 Quarts (9.5 Liters)
Note: Approximate dry fill capacity including transmission fluid cooling system, actual refill capacities will vary based on vehicle application and transmission fluid cooling system (i.e. coolers size, cooling lines, auxiliary cooler capacities). The amount of transmission fluid and fluid level should be set by the indication on the dipsticks normal operating range. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Dec 2, 2019 at 11:37 AM
NANA1127
  • 5 POSTS
How can I let you hear my cars noise with out driving it? That's when it makes the noise and I'm afraid to drive it now don't want to break down and have it towed home. thank you Ken.
Dec 3, 2019 at 2:20 AM
NANA1127
  • 5 POSTS
I checked my transmission fluid when it was cold and i think it's too full. I have a pic of it but I don't know how to send it to you.
Dec 3, 2019 at 6:33 AM
  • 55,694 POSTS
Click the add image or video link below the text box.
Dec 3, 2019 at 7:08 AM
NANA1127
  • 5 POSTS
I found a high pressure leak at a hose going to bottom of my radiator. Can that cause my problem? I got my car cleaned off do I check the fuel be for I start it or after and i unhooked the battery for 30 minutes.
Dec 3, 2019 at 4:33 PM
  • 55,694 POSTS
If the leak you found is transmission fluid then yes that will cause the issue. Can you upload a picture of what you found?
Dec 4, 2019 at 4:15 AM
NANA1127
  • 5 POSTS
It's transmission fluid. I'll get a hose and fix it . thank you have a great day .
Dec 4, 2019 at 9:02 PM
  • 55,694 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Dec 5, 2019 at 2:54 AM
