Transmission problem
1998 AUDI QUATTRO
250,000 MILES • 2.8L • 6 CYL • AWD • AUTOMATIC
BART KOSKI
  • 29 POSTS
When I make tight turns my car feels like the wheels are binding up. Then it makes a loud popping noise like the gears are binding. My rear tire had uneven wear so I purchased new tires and replaced top control arm and before I could get it aligned when i put the transmission in drive there is a horrible grinding noise, but my reverse works fine.
Jun 1, 2016 at 4:29 AM
  • 55,412 POSTS
Hey BART,
It sounds like you have a CV axle that is no good, when the axle wears it will make the noises you have described. Here is an idea on how to replace it.
https://www.2carpros.com/articles/replace-cv-axle
Let me know what you find
Best, Ken
Jun 1, 2016 at 9:03 AM
BART KOSKI
  • 29 POSTS
it lost all forward gears , makes a loud gear grinding sound. reverse works fine
Apr 28, 2017 at 7:35 AM
  • 55,412 POSTS
I would check to make sure the axles are fully installed inside of the transmission, one may have popped out.
Cheers, Ken
May 1, 2017 at 9:11 AM
