transmission not shifting
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
GACHIECIKU
not shifting remains in first, but learned changed oil and used CVT fluid instead of ATF. can that be my problem?
Feb 2, 2018 at 5:51 AM
KHLOW2008
  • 41,812 POSTS
Using the wrong fluid should not be the problem. It would at least work for a short while but in the long run it can damage the transmission.
Transmission not working could be due to insufficient fluid added. Check the fluid level first.
But if the wrong fluid is used, it should be drained and replaced with the correct type.
Feb 2, 2018 at 10:19 PM
GACHIECIKU
Thanks for the answer but the problem was with the revolution sensors that
had been interchanged by mechanic. both sensors use identical connectors so any can fit to both.
Feb 3, 2018 at 5:02 PM
  • 55,694 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Cheers, Ken
Feb 5, 2018 at 4:20 AM
