My SUV was driving completely fine. I pulled away from a stop sign and I started hearing weird noise coming out of my transmission I'm guessing. I immediately thought it might have been a wheel bearing going bad or a CV joint that slipped out. But I don't think that was it and I'm hearing a loud droning from the rear end. I checked the fluids I jacked up the car and shook the tires and whatnot doesn't feel like the wheel bearings are bad or anything. away from a stop sign and I started hearing weird noise coming out of my transmission I'm guessing. I immediately thought it might have been a wheel bearing going bad or a CV joint is slipped out. But I don't think that was it and I'm hearing a load running from the rear end. I checked the fluids I jacked up the car and shook the tires and whatnot it doesn't feel like the wheel bearings are bad or anything. When the tires spin in the snow a little bit, it comes up and says all wheel drive is disabled. It takes a few minutes and it will move again but it still makes that horrible sound. And it doesn't seem like Park is catching my car will roll down my driveway unless I put a brick behind a tire. I want to know could it be a shift solenoid. when the tire spinning the slow snow a little bit, it comes up and says all-wheel drive is disabled. It takes a few minutes and we'll move again but it's still makes that horrible sound. and it doesn't seem like park is catching my car we'll roll down my driveway unless I put a brick behind the tire. I want to know could it be a shift solenoid or something. I purchased the car about 6 months ago. I did an oil change on it myself new plugs and wires and wanted to change the transmission fluid also oh, when I pulled the transmission pan there was not a filter in the transmission. I put a filter in it and new fluid and it's been running fine since then oh, at least a few thousand miles. And then this happened last night. If you would like me to send a video I'm more than willing to do that.
Jan 18, 2020 at 10:06 AM
