Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mazda
b3000
Drivetrain
Transmission
Drive
Transmission problem
1999 MAZDA B3000
171,000 MILES • 3.0L • 6 CYL • 4WD
ISLA770
MEMBER
1 POST
when shifting into drive i could feel some slack. Now it will only drive in reverse. filter changed, no metal shavings in pan or on magnet.
Jun 11, 2019 at 3:31 AM
Experienced Mechanic
It sounds like it could be the gear range sensor but to be sure lets run the codes to see what comes up. Do the reverse lights work?
Here is the sensor so you can check it out. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Image (Click to enlarge)
Jun 12, 2019 at 7:33 AM
Add image or video
Ask a new question
Check engine light
Engine has low power
