Transmission not shifting properly
160,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
PROKOPIS PAPASTRATIS
  • 12 POSTS
i just replaced transmission and installed a used one with 39,000 miles. the car shifts twice only and revs go up to 3,000-3,500RPMs without another shift. i wonder if this is a TCM problem or a speed sensor problem. (Code is generic PO 700 and po 731). previous transmission had a PO 740 code- Torque converter shift solenoid and lasted about 8 months. i did not attempt to replace solenoid because its inside the transmission. When the transmission fluid was getting really hot in the summer the car was shifting 1 to 2 and to 3d with a bang. every time that happened i was restarting and immediately the problem went away. Please advise. Thank you
Nov 12, 2021 at 2:38 AM
  • 110,251 POSTS
The code, P0731, occurs when the PCM detects a first gear’s input speed sensor and transmission output speed sensor. As a result, the vehicle cannot shift properly.
There are a few things that can cause this to set. Something as simple as low or contaminated transmission fluid, a dirty filter reducing line pressure, a TCM that needs to be reprogrammed or replaced, a faulty shift solenoid, and so on.
Are the two codes indicated, the only ones stored? If there are additional ones, let me know what they are.
I attached the diagnostics specific to this code below. Take a look through them and let me know if you are comfortable doing them.
Take care and let me know what I can do to help.
Nov 12, 2021 at 8:14 AM
  • 12 POSTS
thank you for your reply. i don't have the DRBIII scan tool that Chrysler use nor a lift. because as i said before the previous transmission had problems (codes PO700-PO 740-torque converter clutch solenoid etc i let go -solenoid been internal to this transmission-. Transmission lasted for 7 months and went bad 20 days ago. i replace with a use transmission with 39,000 miles on it and i got only 1 code PO731. i feel that is unlikely that the new one is internally bad and i suspect that the TCM is bad / 10 pin electrical connector / speed sensors electrical connections. So, I am thinking to buy a recondition TCM that is going to cost me $200.00. replace the old one and take the Jeep to the dealer and let them do diagnostics according to the service bulletin for PO731, this way i will save a lot of money and i will find out what the problem really is. Also, i wanted to ask you if after i replace the TCM do the dealer has to perform a relearn of the transmission? the TCM will come reprogrammed with the VIN. Your input will be greatly appreciated, Thank you
Nov 22, 2021 at 4:38 AM
  • 110,251 POSTS
Certainly, it could be a connector issue or the module. As far as module replacement, if it is a pre-programmed unit with your specific VIN, it should be plug and play. Nothing additional will need to be done by the dealer.
If you have a chance, let me know how things turn out for you. I'm interested in knowing. Also, let me know if there is anything I can do to help or if you have other questions.
Nov 22, 2021 at 11:48 AM
