Transmission only works in reverse
70,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
TAGA
  • 5 POSTS
The problem is it could go on revers but not on drive.
Sep 29, 2019 at 5:53 PM
Good morning,
Is the check engine light on?
Did you check the fluid level?
Sep 29, 2019 at 8:04 PM
TAGA
  • 5 POSTS
Engine light off fluid level okay.
Sep 29, 2019 at 8:36 PM
Okay, thank you.
It sounds like you have an internal failure in the transmission such as clutch, drum or seals for forward application.
Looks like you will need a rebuild or replacing the transmission.
Sep 29, 2019 at 8:38 PM
TAGA
  • 5 POSTS
Thanks for the information.
Oct 3, 2019 at 9:34 AM
You are welcome.
Always glad to help.
Oct 3, 2019 at 9:37 AM
