Transmission problem
121,000 MILES
TOMB2277
Transmission knocks on a could start. Shutters and slips when slowing down and slips when turning. Shifts fine during normal speeds. Was told it could be a trans pump or actuator switch. Is there a solution without replacing the whole trans?
May 3, 2013 at 10:50 PM
it will not be a simple repair. the pump has or is failing requiring removal and overhaul.
roy
May 3, 2013 at 11:14 PM
TOMB2277
Thank you for your help
May 4, 2013 at 4:53 AM
