Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Bonneville
Engine
Crankshaft
Front Crankshaft Seal
Replace/Remove
After replacing front main seal transmission will engage in drive and reverse but the car will not move
2001 PONTIAC BONNEVILLE
167,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BIGMIKE65
MEMBER
I blew the front main seal on my transmission and I replaced it. The transmission worked fine before the seal blew.
Nov 11, 2019 at 1:37 AM
Experienced Mechanic
Good afternoon,
Did all the fluid leak out when the seal failed?
Did you change the filter in the pan?
If it does not move, you may have a front pump failure or torque converter failure.
Nov 11, 2019 at 2:32 AM
BIGMIKE65
MEMBER
Yes, about 3 quarts leaked out and it had a hard time moving then but I didn't change the filter are anything just replaced the seal.
Nov 11, 2019 at 8:33 AM
Change the filter and add new fluid and see if it moves.
Nov 11, 2019 at 8:37 AM
BIGMIKE65
MEMBER
Thank you. I will do so and let you know.
Nov 11, 2019 at 8:41 AM
Sounds like a plan
Nov 11, 2019 at 8:54 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
