Transmission problem
333,000 MILES • 2.5L • 5 CYL • FWD • AUTOMATIC
AKAISO
Av changed gear oil but problem persists but dash light shows orange not red. In d morning at first drives accelerate well but when d engine hots up acceleration declines as if car that d clutch is burnt. Wen shifting into d or r a loud annoying jolt is heard. Wat do I do? I Haf over 300k miles on d dash of my 5cyl 02 s80 Volvo.
May 2, 2016 at 10:27 AM
MORGANA BRADY
I have a 99 model mutsbishi magna sedan tk v6 auto. When i put it n drive its stuck in nuetral drive and 3rd gear!? Is my gearbox stuffed!?
May 2, 2016 at 12:32 PM
  • 31,937 POSTS
Go get a diagnostic scan done on the transmission, jolting or harsh shifting can be a pressure problem, leaking servos or a number of other internal problems, this will have to be checked first hand, but with the miles on the transmission, i do feel that it will be due for some major work.
May 2, 2016 at 10:34 PM
AKAISO
I did diagnosis,, showed gear speed signal line missing. Whatever that means I don't know.
May 2, 2016 at 11:22 PM
  • 31,937 POSTS
Internal fault with the transmission, go get it looked at by a trans specialist, they will have to do further tests to determine the exact fault and estimated repairs.
May 3, 2016 at 7:32 AM
