Transmission problem
22,000 MILES
VALI
  • 10 POSTS
After a accident in lower part o car, only the valve body and transmission case is damaged. We changed this parts. After repair car work absolutely normal on 50-60 km in city driving. Then when i stop the car on in traffic lights the engine stopped too in transmission drive position but it's doing 2-3 time. Then car works normally again and transmission shifts all 6 gears excellent. In next day i can't drive the car at all. In drive and in rear transmission posision engine stopped. But in neutral and in parking engine works normally, and when i press the brake pedal in this positions nothing changes. Can you advice what we do wrong or what happend after 50-60 km driving? In the dashborad nothing is light. We do diagnostic with Bosch KTS but say its the mechanical problem. He can't find any eror in car.
Apr 21, 2013 at 4:07 AM
new or used trans??
if used, you may have a bad unit.
if new, take it back for warranty work.
it sounds like a control issue with the trans. did you inspect the wiring very carefuly??
Apr 21, 2013 at 4:13 AM
VALI
  • 10 POSTS
We change the transmission outer case. We changed this parts with all a new one. And i forget say we change the all wiring with new one in the inside of transmission. All parts is the original. And they do not give a warranty on the work out of they servise.
Apr 21, 2013 at 4:29 AM
