transmission problem
136,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WILLIAM COBB
transmission wont shift out of first gear has reverse manually shift does but still shifts hard. Does speedometer being stuck have any relevance to problem?
May 7, 2017 at 2:20 AM
  • 55,758 POSTS
Yes, the speedometer has everything to do with the transmission. It sounds like you have a vehicle speed sensor that has gone out and it needs to be replaced.
Here is a diagram to help you get the sensor replaced.
Cheers, Ken
May 9, 2017 at 5:12 AM
