Where is the Transmission pressure sensor/switch located?
124,500 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LONER84
Hello, I need help. I am trying to find the location of the transmission pressure switch for my vehicle listed above. I have been unable to find any information online. Thanks in advance!
Oct 22, 2024 at 10:15 AM
  • 110,248 POSTS
The PCM/TCM relies on three pressure switches to monitor fluid pressure in the L/R, 2/4, and OD hydraulic circuits. These components are integral to the solenoid/pressure switch. The pressure switches can only be serviced by replacing the assembly. (see pic below)
Let me know what codes you have so I can better pinpoint what you are dealing with.
See pic below.
Oct 22, 2024 at 11:48 AM
LONER84
The codes are P0700 and P0870. Thank you
Oct 23, 2024 at 12:29 PM
  • 110,248 POSTS
The P0700 is a generic code that simply indicates there is a code, or codes stored in the TCM. The P0870 is the one of concern and I do see why you indicated the pressure switch. However, there are several things that can be setting that code.
I attached the diagnostics for P0870 below. Take a look through them and let me know if you are comfortable performing them.
Oct 23, 2024 at 1:16 PM
LONER84
I ended up changing fluid, input and output speeds sensors and solenoid. So far it is shifting fine and no lights. I am around 100 miles in since maintenance.
Dec 3, 2024 at 11:47 PM
  • 110,248 POSTS
Thanks for the update. I'm glad to know if is working properly now. Hopefully, it will continue.
Take care of yourself and feel free to come back anytime in the future. Also, if things change, let me know.
Dec 4, 2024 at 11:14 AM
LONER84
Thank you!
Dec 5, 2024 at 10:42 PM
  • 55,676 POSTS
JACOBANDNICKOLAS is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Dec 6, 2024 at 1:54 AM
