Transmission only park and neutral
2007 MERCURY MARINER
218,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
MERCURYESCAPé
  • 13 POSTS
When it's cold drives fine for about 2 miles then no gear except park and neutral overdrive light flashes.
My guess is the bands but before I part her out maybe there's something I missed here. Have already changed, flushed and refiled fluid, cleaned all plugs and such, checked fuses and shift link/cable checked the 2-4 high efficiency band and it's fine.
these are the codes it's throwing:
P0731
P21696
P1714
P17515
P0732
P1000
It started with going into limp mode only had 3rd gear did a fluid flush and refill and then lost all gears. Engine is a V6.
Mar 28, 2021 at 3:31 PM
Good morning,
No, to the bands. This sounds like the front pump or the torque converter may have failed not allowing any pressure build-up in the valve body.
I attached the procedure for testing the line pressure to verify the actual pressures.
I also attached the possibilities for the codes. There is no 21696 code at all. Can you double-check that?
This could be a solenoid issue but needs to be confirmed. You will need an advanced scan tool that can activate the solenoids to verify they are functioning correctly. I attached a wiring diagram as well for you of the transmission.
Line Pressure Test
CAUTION: Carry out Line Pressure Test before carrying out Stall Speed Test. If line pressure is low at stall, do not carry out stall test or further transaxle damage can occur. Do not maintain WOT in any gear range for more than 5 seconds.
CAUTION: The Transmission Tester must be removed from the transaxle and the vehicle harness connected to verify these pressures.
The Line Pressure Test verifies that the line pressure is within specifications.
1. Connect pressure gauge to line pressure tap.
Line Pressure Tap
2. Start engine and check line pressures. Refer to following the Line Pressure Chart to determine if line pressure is within specifications.
3. If line pressure is not within specifications, carry out on-board diagnostics and pinpoint test, air pressure check and repair main control system or pump as required.
Line Pressure Chart (2.3L and 3.0L)
Line Pressure Diagnosis
If the line pressure is low at idle in all ranges check the following items:
^ Low fluid level
^ Restricted inlet filter
^ Loose main body
^ Solenoid body or accumulator body to case bolts
^ Excessive leakage in pump
^ Case
^ Control bodies
^ Sticking main regulator valve or damaged inlet tube seal on inlet filter
^ Damaged gaskets or separator plate
If the line pressure is high at idle in all ranges then check the following items:
^ Main regular valve
^ Solenoid body and wiring harness
^ Run Quick Test referred to in electrical diagnosis
Mar 28, 2021 at 10:18 PM
MERCURYESCAPé
  • 13 POSTS
Well, maybe back when I worked as a mechanic I might have had access to an advanced scan tool but from my home garage not so much is there another way?
I decided to pull the valve body out to see if I could visibly see any blockage I'm not a transmission guy so this is relatively new to me should the springs be loose and bouncing around inside the valve body?
Also the solenoid on the face of the body plastic is loose don't know if that matters much .
I've attached a picture where the spring is loose and bouncing back and forth if you move it marked by the red arrow.
Mar 29, 2021 at 1:51 AM
I would remove that and make sure it is not broken.
The first thing you should have done is the pressure test to see if the front pump is working.
Mar 29, 2021 at 2:13 AM
MERCURYESCAPé
  • 13 POSTS
So I take it a loose spring is a bad thing.
Mar 29, 2021 at 9:45 AM
There should be some tension there.
Mar 29, 2021 at 9:48 AM
MERCURYESCAPé
  • 13 POSTS
Sorry if these are obvious questions like I stated before I'm new to transmission work so bare with me. the other side seems to have the tension and I pulled the springs to figure out why it doesn't have tension and for the life of me I don't see anything. do you happen to have a diagram of the valve body tear down?
Mar 29, 2021 at 10:01 AM
MERCURYESCAPé
  • 13 POSTS
Is there a special sequence to starting after a valve body replacement? Before I go head first into blowing up my transmission I figured I would ask an expert first. I have replaced the valve body with a updated rebuilt one.
Mar 30, 2021 at 11:56 AM
I posted the torque below for you for the valve body.
. Install the main control valve body assembly. Tighten the bolts in the sequence indicated.
^ Tighten to 10 Nm (89 inch lbs.).
I also attached the bolt tightening sequence for the valve body as well.
Mar 30, 2021 at 12:06 PM
MERCURYESCAPé
  • 13 POSTS
Yes, I already did all that and tightened in correct sequence etc. I guess I wasn't very clear my apologies what I meant is there a special start up procedure? I.E. for resetting the transmission and or smooth pairing with new valve body. My Volkswagen Touareg had to relearn the throttle anytime you took the throttle body off. that's why I ask.
Mar 30, 2021 at 12:59 PM
Okay, no, there is no start-up procedure or programming. It is a plug-and-play. Just verify the fluid level is correct.
Mar 30, 2021 at 9:21 PM
MERCURYESCAPé
  • 13 POSTS
Thanks for the help.
Mar 31, 2021 at 4:37 AM
You are welcome.
Always glad to help.
Mar 31, 2021 at 5:04 AM
MERCURYESCAPé
  • 13 POSTS
Well, this is frustrating. Not sure where I went wrong here but replaced the valve body torqued it to spec and in correct sequence hooked it up put everything back together and it won't even try to start the relays click but no crank. Any ideas?
Mar 31, 2021 at 6:13 AM
Okay, I attached a wiring diagram of the starting system for you to view.
Make sure the range sensor on top of the transmission is tight and the connector is all the way in. This would be the only connection with the starting system from this repair. I attached some pictures for you below.
Mar 31, 2021 at 6:27 AM
MERCURYESCAPé
  • 13 POSTS
Is this in drive or neutral the pictures? I've looked at it's hard to tell.
Mar 31, 2021 at 2:00 PM
I cannot tell from that picture. Have someone in the car with their foot on the brake and start it and run through the gears. Then you can be sure what gear it is in.
roy
Mar 31, 2021 at 10:00 PM
MERCURYESCAPé
  • 13 POSTS
Update: I have replaced the transmission valve solenoid and valve body after one of my buddies told me that was the issue since he has more experience with transmissions than myself. unfortunately it seems to only want to shift gears when the engine is cold once warmed up it has a problem with shifting into any gear, then if I turn it off open and close the driver door and lock letting everything power down fully. then when I start it and put into gear it works for about 200 feet then fails again. Any thoughts my buddy is stumped?
Apr 20, 2021 at 12:32 PM
Okay, back to the beginning. Did you ever check the line pressure as I suggested? This sounds like you have an internal failure but you need to confirm it.
Apr 20, 2021 at 8:03 PM
MERCURYESCAPé
  • 13 POSTS
I got a pressure testing kit today haven't had a chance to do the test yet but scanned for codes and only got one code back p0720 the oss sensor, but would that cause my issues?
Apr 22, 2021 at 8:38 AM
No, it will not.
Do the line pressure test and keep me updated.
Apr 22, 2021 at 9:05 AM
MERCURYESCAPé
  • 13 POSTS
Okay so did the test .
Idle. Stall
P/n. 60-75. 0-60
R. 60-75. 120-150
D. 30-90. 0-30
2. 30-50. 0-20
1. 30-50. 0+
Apr 22, 2021 at 11:24 AM
As you can see, the drive is too low. It is under half of what it should be.
Looks to be an internal failure. You will need to replace it with either a rebuilt unit or a used unit.
I attached a YouTube video of the replacement.
https://www.youtube.com/watch?v=sU8ZL5uSOVQ
https://www.youtube.com/watch?v=9F1oJZxCvMg
Apr 22, 2021 at 7:20 PM
