Transmission oil replacement
110,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
EBIMESH
  • 6 POSTS
What is the oil to be used for transmission (automatic 4 AT)?
Feb 16, 2018 at 2:24 PM
STEVE W.
  • 15,404 POSTS
Everything I find shows you can use Dexron III or Ford Mercon ATF in it.
Feb 16, 2018 at 3:53 PM
EBIMESH
  • 6 POSTS
Thanks.
May 3, 2018 at 7:46 PM
  • 55,691 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
May 6, 2018 at 9:48 AM
BBOSA LUTALO DENNIS
Presea 1995 ,which type of ATF should I use?
Mar 24, 2023 at 3:14 AM
  • 55,691 POSTS
Presea is Nissan Matic D ATF. It is important to use the recommended oil to ensure optimal performance and longevity of the transmission.
Mar 24, 2023 at 3:25 AM
BBOSA LUTALO DENNIS
Thank you and how many litres should I use?
Mar 24, 2023 at 3:55 AM
BBOSA LUTALO DENNIS
How many litres of nissan magic d ATF is needed for Nisssan presea 95 R11,engine GA15De?
Mar 24, 2023 at 4:11 AM
  • 55,691 POSTS
The approximate capacity for a standard transmission is around 7.6 liters (8.0 US quarts) of ATF.
Mar 26, 2023 at 5:27 AM
