Transmission oil leak at cooler line
165,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
BUCKSHOT60
I replace with new line that on top ,bolt on top of transmission an still leaks around bolt head that line is bolted to tans
Jul 28, 2015 at 6:21 AM
KHLOW2008
  • 41,812 POSTS
Were the washers replaced?
Jul 29, 2015 at 2:50 AM
BUCKSHOT60
Washers. No there wasn't no washers on the original part. Metal to metal There's a YouTube video showed how mine is leaking. Oil comes from around it as they drive it. But there wasn't no washers on factory part that I took of.
Jul 29, 2015 at 6:36 AM
KHLOW2008
  • 41,812 POSTS
Between the bolt and the pipe joint there should be washers at both sides.Seems they were not installed previously or were they stuck to the pipe you removed?
Jul 30, 2015 at 3:04 AM
BUCKSHOT60
I was very careful in removing line an watched for washer or gasket but if your saying. There were washers there. Then. I'm not sure. Why they wasn't any there. If they take washers then Are they copper
Jul 30, 2015 at 7:00 PM
KHLOW2008
  • 41,812 POSTS
OEM uses aluminium washers to prevent leakages.
Copper washers can be used as substitute.
Jul 30, 2015 at 10:58 PM
BUCKSHOT60
Well I put aluminum washers above an below. Sat it was before I started. It already had one on top. Must not have seen the one on bottom ,, anyway. The leak is still there. New line new washers an it leaks just like it did before I started. I wiped off all around where it's bolted down. It's clean. It doesn't leak ideal ing I put on stands. Took tires of. Block it. Put in gear. Doesn't start leaking unless I raised rpm while in gear about 20 to 40 mph. Then it started leaking in that area I wiped oil of. Over an over it still does it like seeping from there. Has any one else have this problem. There's a you tube same thing going on. Thank you for your help
Aug 7, 2015 at 5:54 AM
KHLOW2008
  • 41,812 POSTS
Check for cracks along the threads. Overtightening by previous owner could have damaged it. Try using some packing tape around the washers to see if it helps.
Leaking only at high speed occurs when the pressure is high.
Aug 8, 2015 at 12:50 AM
