Well I put aluminum washers above an below. Sat it was before I started. It already had one on top. Must not have seen the one on bottom ,, anyway. The leak is still there. New line new washers an it leaks just like it did before I started. I wiped off all around where it's bolted down. It's clean. It doesn't leak ideal ing I put on stands. Took tires of. Block it. Put in gear. Doesn't start leaking unless I raised rpm while in gear about 20 to 40 mph. Then it started leaking in that area I wiped oil of. Over an over it still does it like seeping from there. Has any one else have this problem. There's a you tube same thing going on. Thank you for your help
Aug 7, 2015 at 5:54 AM
