Transmission oil cooler line specs needed?
2001 MERCEDES BENZ C320
146,000 MILES • 3.2L • 6 CYL • AUTOMATIC
CJDURAN515
  • 9 POSTS
I am in the process of replacing the fitting on my transmission oil cooler line, but I can’t find the actual size if the lines anywhere and I’ve literally looked everywhere I could possibly think it might be noted. I even went to a library! If anyone knows the specs I’d appreciate the information.
Dec 4, 2022 at 2:18 PM
  • 110,240 POSTS
Unfortunately, that isn't something that is provided in the parts manual. Can you tell me the exact part that you are replacing? If I recall, these hoses are rubber and steel and the connector at the end is a female connector and can't be replaced. Let me know.
Also, if you can take a pic of what you are replacing, it may help me.
Whenever I make a new steel line for the brakes or the cooler lines, I usually take the old part to the parts store to match it. I'm not sure if you have tried doing that.
Dec 5, 2022 at 10:36 AM
