Transmission oil cooler hoses?
270,000 MILES • 1.8L • AUTOMATIC
YAZIDAN
  • 141 POSTS
Hi
I need to replace transmission oil cooler hoses .which one I need to use SAE 100R6, SAE J1532 type A,B, AT,BT or SAE J1019. also what size are they 5/16, 3/8 ?
Thank you
Jul 2, 2026 at 7:33 PM
  • 55,851 POSTS
The transmission-cooler hose is normally 3/8-inch inside diameter. Before buying it, measure the metal cooler-line nipple where the hose attaches; it should be approximately 3/8 inch. The SAE J1019 high-temperature oil hose can also be used for automatic transmission fluid, but SAE J1532 is the more directly applicable specification. Let me know if you need anything else.
Jul 3, 2026 at 11:42 AM
