Transmission oil change
103,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TIM STILLWAGON
How many quarts of transmission fluid when changing fluid and filter? Book says four quarts.
Jul 27, 2018 at 11:41 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial showing how to change the automatic transmission fluid:
I've attached 2 pictures below of the transmission capacities you've requested. One is for a 3 speed automatic and the second is for a 4 speed automatic. I've attached both below. Both use DEXRON- III type transmission fluid. Hope this helps and thanks for using 2CarPros.
Dec 8, 2020 at 10:32 AM
