Good evening, the vehicle's Transmission is not responding or moving when place in drive position, I scanned the vehicle the only code found on its memory is P0776. I removed the sump to access the solenoid, I applied voltage to them, all of them were clicking, then I erased the code from its memory after the test drive it works fine, after parking the vehicle for some time the code appeared again with the same symptoms. What could be done?
Oct 15, 2021 at 5:19 AM
