Transmission not moving in drive
134,264 MILES • 6 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Good morning, the vehicle transmission had just been replaced recently, now the transmission is moving on R (reverse) alone, when place in D (drive) it won't move. I scanned the vehicle the following codes were retrieved.
Dec 30, 2020 at 5:54 PM
Good morning, nice to hear from you.
Is this a new or used transmission?
Did you have the TCM programmed after installing?
I attached a wiring diagram for you to view. Check the fuses in the diagram for power on both sides.
This sounds like a bad transmission.
The 500 is for the vehicle speed sensor.
The U code is a no communication issue with the TCM.
1. REMOVE BATTERY
2. REMOVE AIR CLEANER ASSEMBLY
3. REMOVE SPEED SENSOR (NT SENSOR)
(a)Disconnect the speed sensor connector.
(b)Remove the bolt and speed sensor.
4. REMOVE SPEED SENSOR (NC SENSOR)
Dec 30, 2020 at 8:14 PM
BLESSING EWOBOR
  • 753 POSTS
It is used transmission and I didn't program the transmission because I used the TCM that came with the vehicle.
Dec 31, 2020 at 1:45 AM
I understand but the TCM has the VIN from the donor, not the vehicle it is installed. The VIN must match.
Dec 31, 2020 at 4:57 AM
BLESSING EWOBOR
  • 753 POSTS
After the replacement of the transmission, the vehicle has been performing well before this issue.
Dec 31, 2020 at 12:00 PM
BLESSING EWOBOR
  • 753 POSTS
And the TCM that came with the used transmission has a broken case.
Dec 31, 2020 at 12:01 PM
Okay, it still needs to be programmed to your car.
Dec 31, 2020 at 12:18 PM
BLESSING EWOBOR
  • 753 POSTS
How can it be programmed?
Dec 31, 2020 at 12:30 PM
That needs to be done either by the dealer or someone with the software to perform this.
You can use the original RCM and have that programmed.
Dec 31, 2020 at 6:52 PM
BLESSING EWOBOR
  • 753 POSTS
Could techstream perform it or what is the name of the software used?
Dec 31, 2020 at 8:44 PM
Toyota has there own scan tool.
Snap-on will perform this but you will need a subscription to Toyota technical site.
Jan 2, 2021 at 7:14 PM
BLESSING EWOBOR
  • 753 POSTS
Thank you, I will get back to you sir.
Jan 2, 2021 at 9:47 PM
You are welcome.
Always glad to help.
Jan 2, 2021 at 9:52 PM
