I was driving from work and my transmission down shifted itself barely made it home I noticed it would go to second gear I checked the transmission fluid and it's really dark and smells burnt now when I put the car in park or neutral it makes a whining noise but as soon as I put it into drive or reverse the noise stops but the car doesn't move
SPONSORED LINKS
Sunday, January 3rd, 2016 AT 3:42 PM
JOHNNYT73
MECHANIC
If the fluid level is good, and the fluid looks and smells burnt then most likely that transmission has burned out. I would look into replacement, but not before professionally diagnosed.
