Transmission not engaging
25,400 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
JOSEPH TREADAWAY
  • 8 POSTS
So i started doing routine checks transmission was low topped it off brake fluid a little low topped it off changed cap rotor button, plugs and wires ran like a top. two days later the transmission loses power will not move. i shut of the SUV started perfect it moved then lost power again. i shut it off thinking it may be over heating let it sit started it had power pulled off shifted fine then lost power. i was able to get it home on this fashion. I got up this morning now it wont start, it will turn over but not start. I do not know what to do. can it be related to the transmission problems?
Dec 20, 2016 at 12:51 AM
HMAC300
  • 48,601 POSTS
probably not a transmission problem. have battery checked for condition including load test then try resetting security system if that all is okay, then scan for codes and check fuel pressure with a gauge auto parts rent it. also, check fuses under hood. See links.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Dec 20, 2016 at 3:38 AM
RENEE L
  • 1,260 POSTS
Hello JOSEPH,
If you decide to check the condition of your battery yourself here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself.
If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
All the best,
Renee
Admin
Dec 20, 2016 at 5:00 AM
JOSEPH TREADAWAY
  • 8 POSTS
Was not the battery it was my coil that went out and overheated transmission. put in an inter cooler changed filter and fluid and back on the road.
Dec 23, 2016 at 10:31 PM
CJ MEDEVAC
  • 11,000 POSTS
Should you or your pals need assistance later, Come back to see us!
Merry Christmas!
The Medic
Dec 24, 2016 at 6:39 AM
JOSEPH TREADAWAY
  • 8 POSTS
Well on a sad not must have been a temporary fix ran great for about a week then no start but i so i checked battery 13. 4 volts got spark fom coil with pulse but still no spark was checking for codes and pulled codes for injector leak but what gets me is as i pump gas and and turn over engine i smell no fuel what so ever and i also see no spray in carb but got fuel at rail really scratching my head on this one
Jan 2, 2017 at 4:22 AM
HMAC300
  • 48,601 POSTS
what was the code? it may be a fuel pressure problem or injector may be staying open to long...
Jan 2, 2017 at 5:44 AM
JOSEPH TREADAWAY
  • 8 POSTS
It was a code 12
Jan 3, 2017 at 1:26 AM
HMAC300
  • 48,601 POSTS
see pics for testing maf circuit
Jan 3, 2017 at 3:56 AM
