I figured out that it is not coming out of drive
162,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JASON HEWETT
Truck was driving great until I came to a stop sign. Went to take off and the truck just started stumbling and not getting any power. Later I figured out that it is not coming out of drive. So I tried shifting it manually and that worked. It has codes popping up on the diagnostic scanner saying all the solenoids are not functioning. What would cause this? Bad speed sensor?
Jan 23, 2018 at 12:21 AM
  • 55,849 POSTS
Yes, that is what I was going to say. I would replace the output sensor. Below are the locations.
I would run the codes as well.
Please run this test and get back to us.
Cheers, Ken
May 4, 2021 at 3:06 AM
