Neutral safety switch on my truck listed above the switch itself is supposed to have a 3-wire plug. But the wiring harness on truck has a straight 6 wire plug. I just changed motor and transmission and I’m sure the reason for the difference is they aren’t the same year transmission. But what do I do with a 6 wire plug and a 3-wire neutral safety switch? The old transmission switch will not fit into the recent one. What is the fix to this? Every and all other wiring worked out but this. Need to know what is the fix please.
Jan 16, 2025 at 6:18 PM
