Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
BMW
528i
Drivetrain
Transmission
Mount
Replace/Remove
How to replace the transmission mounts?
2012 BMW 528I
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
TALONLUVSWIFI
MEMBER
Hi, can you please tell me how to replace the transmission motor mounts on the vehicle listed above?
Jun 20, 2024 at 3:18 AM
Experienced Mechanic
Yep, here are the instructions on how to replace the transmission rubber mount.
Remove transmission cross-member with rubber mount.
Remove rubber mount from transmission cross-member.
Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Jun 20, 2024 at 10:11 AM
Add image or video
Ask a new question
