Cannot move gears. it is stuck in the parking gear.
Oct 26, 2017 at 11:29 PM
KHLOW2008
✓Experienced Mechanic
Hi Walter,
The shift interlock system has malfunctioned resulting in the gear shift being locked. Check if the brake lights are working. If not, it could be a blown fuse or a bad brake switch. Worse of the problem would be a faulty interlock solenoid/module.
K H Low
Oct 27, 2017 at 12:16 AM
WALTER2017
MEMBER
This morning when I started the engine I saw a message of transmission malfunction may be resolved with restarting the car, but restarting it did not help. I cannot change gears, just to neutral. Any advice? Thank you
Images (Click to enlarge)
Oct 27, 2017 at 7:44 AM
(Merged)
You need to first check oil level and see if your transmission will set codes. post any codes here for further assistance.
(Merged)
WALTER2017
MEMBER
p2720 pressure control solenoid, control circuit low.
Oct 28, 2017 at 2:36 AM
There are several fuses and a hydraulic pump relay that can go out which will cause the problem you are describing.
Here are some guides that will help you get the job done:
