Transmission malfunction after alternator replacement
2013 FORD FOCUS
214,000 MILES • 2.0L • TURBO • 2WD • AUTOMATIC
TSHEPISO.FORD
I just replaced my vehicle alternator after the outside fan belt pulley failed. After this, the engine is running but when you put the vehicle on D or R gears, the car doesn't move and displays "transmission malfunction". What do I need to do?
Jan 2, 2020 at 12:13 AM
  • 110,244 POSTS
Is the shift indicator showing the correct gear selection? Also, is the check engine light staying on when the engine runs?
I have to ask, was the alternator bad? You indicated the pulley broke.
I checked through my manual, and there is a section specific to this message. It indicates a problem with either the body control module (BCM) or the transmission control module (TCM). The alternator shouldn't have affected either of those unless it was over charging.
First, I need you to check two fuses in the under hood fuse box. Fuses F15 and F41. See pic 2 below for location. Here are a few links you may find helpful:
If the fuses are good, here is the test procedure which requires specialized tooling. The pic attached is the actual diagnostic flow chart. I realize this is something you may not be comfortable with, but wanted to add it so you could see what will need done.
2013 Ford Focus L4-2.0L Turbo
Pinpoint Tests BK: A Transmission Malfunction Display Is Never Or Always ON
Vehicle Instrument Panel, Gauges and Warning Indicators Testing and Inspection Pinpoint Tests Instrumentation, Message Center and Warning Chimes Pinpoint Tests BK: A Transmission Malfunction Display Is Never Or Always ON
PINPOINT TESTS BK: A TRANSMISSION MALFUNCTION DISPLAY IS NEVER OR ALWAYS ON
Pinpoint Tests
A Transmission Malfunction Display Is Never Or Always On
Diagnostic Overview
Diagnostics assume a certain skill level and knowledge of Ford-specific diagnostic practices.
REFER to: Diagnostic Methods See: Vehicle > Initial Inspection and Diagnostic Overview > Diagnostic Methods (General Information). See: Vehicle > Initial Inspection and Diagnostic Overview
Normal Operation and Fault Conditions
See Transmission Malfunction Displays.
REFER to: Message Center - System Operation and Component Description See: Instrument Panel, Gauges and Warning Indicators > Components > Message Center - System Operation and Component Description (Instrument Panel, Gauges and Warning Indicators).
Possible Sources
- TCM (transmission control module)
- BCM (body control module)
_________________________________________________
Let me know what you find with the fuses. Also, if you have other questions, please feel free to ask.
Jan 2, 2020 at 3:08 PM
