Transmission malfunction
141,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SWAMPY1958
The battery light came on after 30 seconds, but was still charging at 14.3v until the light came on then dropped to 13.2. so removed battery. After removing the battery to be charged i replaced it then a fault came up. Transmission malfunction Engine malfunction and it will not do anything now.
Jan 18, 2021 at 7:39 PM
Good morning,
What is the code that was sent? I need the number.
Does the transmission engage in any gear?
Does the engine start? If not check your cable connections.
Jan 18, 2021 at 9:35 PM
