Transmission making noise
155,000 MILES • 4.0L • V6 • RWD • MANUAL
07MUSTANGS197
  • 5 POSTS
I have a five speed manual transmission and it has been making a clinking noise as I drive along and the clinking speeds up the higher the rpm's. what could be the problem?
Nov 16, 2016 at 8:29 AM
HMAC300
  • 48,601 POSTS
it could be a broken tooth in the transmission or maybe a driveshaft noise like bad u-joints. check fluid in transmission, then try to see if it in all gears or just one. If just one gear then it is a transmission noise. also, if you have any loose panels under car they can give funny noises as well.
Nov 16, 2016 at 8:51 AM
07MUSTANGS197
  • 5 POSTS
Along with the clinking noise which happens in any gear there is a lot of vibration under the car around 80mph or higher
Nov 18, 2016 at 2:53 AM
HMAC300
  • 48,601 POSTS
check ujoints in driveshaft those will click when going bad. if you see rust around the seals replace the ujoints they will cause vibrations as well. normally at a lower speed however
Nov 18, 2016 at 4:08 AM
