Transmission line connector
99,305 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
CORY2427
  • 293 POSTS
I’m replacing both transmission lines on truck and was wondering if I could use the old connectors or if I should get new ones and how many?
Jan 12, 2019 at 2:34 AM
KENW1
  • 213 POSTS
Thanks for visiting 2CarPros.
I suggest replacing them as a best practice. There are two required, part# 52119547AA .
Jan 12, 2019 at 3:28 AM
CORY2427
  • 293 POSTS
I’d them the one on side of transmission what about ones in the radiator?
Jan 12, 2019 at 3:29 AM
KENW1
  • 213 POSTS
The ones on the radiator should be a flared tube with brass connector. These usually do not require replacement unless cracked.
Jan 12, 2019 at 5:00 AM
CORY2427
  • 293 POSTS
Sorry to ask so many questions. but how do you bleed air out of transmission once I change it or is it required?
Jan 12, 2019 at 12:57 PM
DOCFIXIT
  • 18,828 POSTS
No need to air bleed Why replacing lines?
Jan 15, 2019 at 4:15 AM
