Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Dakota
Drivetrain
Transmission
Line
Replace/Remove
Transmission line connector
2006 DODGE DAKOTA
99,305 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
CORY2427
MEMBER
I’m replacing both transmission lines on truck and was wondering if I could use the old connectors or if I should get new ones and how many?
Jan 12, 2019 at 2:34 AM
KENW1
Experienced Mechanic
Thanks for visiting 2CarPros.
I suggest replacing them as a best practice. There are two required, part# 52119547AA .
Jan 12, 2019 at 3:28 AM
CORY2427
MEMBER
I’d them the one on side of transmission what about ones in the radiator?
Jan 12, 2019 at 3:29 AM
KENW1
The ones on the radiator should be a flared tube with brass connector. These usually do not require replacement unless cracked.
Jan 12, 2019 at 5:00 AM
CORY2427
MEMBER
Sorry to ask so many questions. but how do you bleed air out of transmission once I change it or is it required?
Jan 12, 2019 at 12:57 PM
DOCFIXIT
No need to air bleed Why replacing lines?
Jan 15, 2019 at 4:15 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
