Had the flywheel changed and now have a transmission leak, but dealer says it has nothing to do with the replacement. Never had a leak before.
Apr 5, 2019 at 1:58 PM
✓Experienced Mechanic
Welcome to 2CarPros.
Can you tell approximately where it is coming from? Does it appear to be from the transmission pan, one of the seals where the shifter levers enter the transmission, or does it appear to be coming down below the bell housing (where the transmission and engine join together)?
Apr 5, 2019 at 2:13 PM
