I have changed the filter under the pan and installed a new gasket on the pan. What else could it be?
May 5, 2016 at 4:29 AM
HMAC300
✓Experienced Mechanic
if it is still leaking best bet is to clean it off and see where it comes from. If it is coming from the vent then have a transmission professional look at it because it should not come from the vent. it could also come from any o-ring or seal that is on the outside.
