transmission leak
12,000 MILES • AUTOMATIC
KELBONE PLUS
There is smoke coming from exhaust and the transmission fluid is leaking some how. I know because I put two quarts in and it was empty within two days.
Nov 7, 2016 at 6:42 PM
HMAC300
  • 48,601 POSTS
have engine cooling system pressure checked for leaks and also check lines on transmission going to radiator for leaks. finally see if you see oil in coolant bottle transmission cooler may be leaking into radiator.
Nov 7, 2016 at 10:02 PM
