Transmission leak
100,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
SHELBY5150
  • 15 POSTS
My transmission is spitting fluid out of the access port on the Bellhouse while idling but not driving.
Jan 7, 2022 at 11:41 PM
SQM
  • 6,383 POSTS
Can you upload a picture of where it is leaking from?
Is it from the fill plug on the top of the transmission (some of these do not have a dipstick).
Did you have this serviced recently?
Let me know what you get.
Jan 8, 2022 at 8:05 AM
SHELBY5150
  • 15 POSTS
I have not had it serviced at all. I just tried to fill it up with fluid and it still won't even go into 1st now. I will upload a picture in the morning when it is light out and I can get a good picture. Also this has a dipstick.
Jan 8, 2022 at 1:02 PM
SQM
  • 6,383 POSTS
Got it. I will look out for your upload.
Jan 8, 2022 at 1:06 PM
SHELBY5150
  • 15 POSTS
This is where it's coming from which is the access port to the torque converter. Before when it wouldn't shift all I needed to do is fill the Transmission fluid back up and it would drive fine. Well, today I filled it and put it in drive, and it won't move an inch forward.
Jan 9, 2022 at 9:48 AM
SQM
  • 6,383 POSTS
It almost appears a piece is missing on the housing, which is allowing all the fluid to come out. Do you know if the car ran over something or hit a rock of some kind?
Keep in mind that if there is little or no fluid the transmission will not shift. As it will not have any fluid pressure to do so.
Jan 9, 2022 at 10:50 AM
SHELBY5150
  • 15 POSTS
Okay, I understand that there is the rubber plug missing that covers that hole, but my question is When removing a transmission at the point of needed to access the torque converter bolts in the bellhousing "There should be no fluid coming from where you access each nut, correct?" So how many quarts does it take from completely empty in order for it to register and go into gear? Which seal could it be if it was coming from that hole?
Jan 9, 2022 at 5:45 PM
SQM
  • 6,383 POSTS
That is correct, removing a cover from access hole will not make it leak fluid.
The leak could be from the torque converter seal or the converter itself can leak as well.
This transmission takes 8.6 quarts as the complete capacity. That includes all the fluid.
Jan 10, 2022 at 12:13 PM
SHELBY5150
  • 15 POSTS
So, would you recommend replacing the whole transmission or pulling the torque converter and replacing that and the seal??
Jan 10, 2022 at 12:47 PM
SQM
  • 6,383 POSTS
Well, that will depend on a few factors. Like if there is any other issue with the transmission?
If leaking fluid is the only problem, repairing that would be ideal.
However, if there are other issues like hard shifting or others then replacement or rebuilt might be the way to go.
So, it is all about the current condition/issues.
Jan 10, 2022 at 1:01 PM
SHELBY5150
  • 15 POSTS
Could you send me a link for replacing the seal? Please and thank you.
Jan 10, 2022 at 4:09 PM
SQM
  • 6,383 POSTS
Replacing the seal will require removal of the converter, to do that you will have to remove the transmission.
Look below for the seal replacement instructions.
If you need the transmission removal info just let me know.
Jan 11, 2022 at 4:11 AM
SHELBY5150
  • 15 POSTS
Yes, please send that how to. Also do you have a video on the seal replacement by chance?
Jan 11, 2022 at 10:12 AM
SQM
  • 6,383 POSTS
On this vehicle Mazda used 2 different transmissions.
FS5A-EL and AW6A-EI. One is 5 speed and other 6 speed automatic.
Do you know which one you have?
Jan 12, 2022 at 12:46 AM
SHELBY5150
  • 15 POSTS
5 speed
Jan 12, 2022 at 2:18 AM
SQM
  • 6,383 POSTS
I have attached the transmission replacement procedure below.
Any questions, feel free to let me know.
Jan 12, 2022 at 5:53 AM
