Transmission just stop working it does not move at all
187,000 MILES • 4.2L • V8 • AUTOMATIC
DAMONEY ANDERSON
I don't know what happened to my transmission. I have the car listed above. it was running great until one day I heard a loud noise on the passenger side under the hood then my transmission started slipping. Now when you in park the car vibrates hard and shake until you put in drive then the car idle real low and stop vibrating and shaking, but it will not drive when I push the gas. it start back vibrating and still want go I don't know what that is. can you help?
Dec 19, 2019 at 12:13 PM
  • 110,251 POSTS
Did you notice any leaks? Also, is the check engine light staying on when the engine is running? Have you checked the transmission fluid level?
As far as the noise you heard, were you driving at the time? Also, when you place it in gear and press the gas, does the engine just rev as if it is in neutral?
Let me know,
Dec 20, 2019 at 12:40 PM
