Transmission issues
245,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
CHRISTY BRYANT
  • 10 POSTS
About 30 seconds after I start driving my overdrive light will start blinking and almost simultaneously the odometer will go blank. Well it turns to six dashes. The speedometer also doesn't work anymore. It throws the code 0720 for the oss but it's been replaced twice. I'm at a loss so any ideas would be greatly appreciated.
Oct 14, 2019 at 5:34 AM
Good evening,
The 720 is for the circuit for the out speed sensor. not the sensor itself.
Do you have a scan tool that can read live data?
Also, the overdrive light is an indicator of a fault in the torque converter. That needs to be checked as well.
When was the last time you changed the oil and filter in the transmission?
Ro
yP0720
Descriptor
Insufficient Input From Output Shaft Speed Sensor
Probable Causes
Output Shaft Speed (OSS) Sensor Circuit Open
Output Shaft Speed (OSS) Sensor Circuit Shorted to Ground
Output Shaft Speed (OSS) Sensor Circuit Shorted to Power
Output Shaft Speed (OSS) Sensor Damaged
Output Speed Sensor (OSS) Sensor
Powertrain Control Module (PCM)
Powertrain Control Module (PCM) Damaged
Oct 14, 2019 at 8:26 AM
CHRISTY BRYANT
  • 10 POSTS
Changed the fluid and filter maybe 3 weeks ago. Did engine oil at the same time. We have done everything we could possibly think of right down to ordering a new computer. I'm not sure if my scan tool can read live data or not....
Oct 14, 2019 at 8:32 AM
Okay, you have 2 issues. One is electrical for the 720 and also a torque converter. Do not waste your money replacing ant parts.
Oct 14, 2019 at 8:53 AM
CHRISTY BRYANT
  • 10 POSTS
We put a whole new wiring harness on it too. Shouldn't that have fixed the electrical issue?
Oct 14, 2019 at 9:41 AM
Testing needs to be done to determine the area of failure.
Oct 14, 2019 at 9:54 AM
