Car stalls in reverse?
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICK DAVIS2
When I shift into reverse, the car shuts off. If I quickly bypass reverse and select drive, it drives. However, if I slip it into neutral it sounds like the transmission is going to fall out.
Jan 7, 2021 at 10:18 AM
  • 55,743 POSTS
I have seen a broken air intake tube cause this, but we should start with a code scan. this guide can help us:
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jan 8, 2021 at 10:33 AM
