Transmission issues
200,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
MISTY ZIPF
  • 6 POSTS
I just replaced the transmission in my car, and made sure that all sensors and connections were cleaned. I also flushed the transmission and cleaned the solenoids. It was driving quite well for a short while shifting as it should and not slipping. But, I have noticed that the longer that I drive, and the warmer the car gets the harder it is for it to shift, and it sticks or hesitates from third to four-D? What could possibly be my issue now? Someone please give me some good advice to trouble shoot!
Thank you!
Jun 14, 2017 at 6:23 PM
HMAC300
  • 48,601 POSTS
I am assuming this came from a junkyard so check fluid for color if dark brown or black, I t may be the transmission. if all adjustments are correct then it can also be the seal is hard in clutch pak causing this. if you have a check engine light scan for codes.
Jun 14, 2017 at 10:48 PM
