Transmission will not shift into neutral when starting?
230,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ADRIAN81
My truck won't go into gear when I start it, I have to cycle the key quite a few times and then it will shift into neutral. I'm trying to figure out the problem.
Dec 25, 2024 at 2:12 AM
  • 55,743 POSTS
Can I ask if you mean the gear selector will not move or it moves but the transmission will not engage? If it is the latter I would check the transmission fluid level and if that is okay, I would run the codes, here are guides to help us see what's going on:
and
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please go over these guides and get back to us.
Dec 26, 2024 at 4:58 AM
ADRIAN81
The gear selector doesn't move.
Dec 31, 2024 at 3:02 AM
  • 55,743 POSTS
Okay, so it sounds like the shift lock is not working, I would check the B/U LP fuse and the BTSI fuse both are under the hood. Here is a guide to help and test the fuses, also if the fuse is okay here is the location of the shiftlock and how to adjust or replace it in case the fuses are okay.
Can I ask if the brake lights work? Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Dec 31, 2024 at 3:50 AM
